A bit of a mystery, this.
I found this broken stud lying on the road yesterday. My first thought was that some poor sod is going to discover (hopefully not the hard way) that one wheel of his vehicle is not as well attached as it should be. But then I realised that the broken bit of stud in my hand was very oily. And oil is not at all common on wheel studs. So—what's is it from?
The thread is metric fine, M12 x 1.25. The split tapered thingy suggests that the stud held something which required accurate centring, like a wheel. The broken end has the remains of an unidentifiable thread.
If you look carefully at the filthiest end of the thread in the picture of the bare stud, there is some wear evident on the peaks of the thread. This wear is on only one side of the stud, suggesting some sort of uneven stress.
How would that wear occur? And if this is not a wheel stud, what is it?
