The cross-feed dial on my 13" South Bend lathe has never locked making it nearly useless. I finally got around to taking it apart and there's a sleeve that blocks the pin from contacting the shaft. Would I be correct in thinking that the sleeve is an adapter because the dial is from another machine? My first thought is to drill a hole in the sleeve so the pin can pass through it.
SB13 Dial
That sleeve may be intended to be held tight between features on the shaft (nuts, collars, etc) that take up end play. That way you can reset the dial to zero as needed, without the dial having to take the tightening, which would make it hard to turn.
I made a similar system for my Logan, for just that reason.4357 2773 5647 3671 3645 0087 1276
Ok, the pin goes into the cross feed shaft and the slot in the collar engages with it. The collar turns with the shaft. The micrometer graduated collar goes over the sleeve and the finger screw tightens down on the sleeve to lock it to the cross feed shaft through the collar. This design was the last design SB used for the cross feed, earlier versions used the same micrometer collar but without the sleeve and pin. You may need only the pin if your cross feed shaft has a hole for it, or you may have to drill the hole if it's a earlier shaft.
I see that there's the locking screw and a short pin. Those are typically brass or aluminium so you don't score the bushing. But being a softer material they can become swaged shorter and thicker over time and might not fit through the hole any longer. You may just need a new pad pin. Or in some way reduce the diameter of the old one so it can fall through the index dial's hole.Chilliwack BC, Canada
