When the conditions are such that a lathe is not available, or a lathe is too featureless or lightweight to produce sufficient threads, what are the options for producing straight threads?
Basically all hand wrenched threads are crooked. For some purposes even a very slight misalignment will cause problems, such as tubular structures that have long distance between the attaching point and the critical point. Imagine for example a suppressor, which has to be concentric or it will destroy itself from the first shot.
So, what are the options for making straight threads? Are thread dies true to their faces in general so they could be supported to align them with the part? All options can be considered, including 3D printing jigs and buying stuff that may be even a bit expensive, but obviously "just buy a lathe", although being a problem solver, would not suffice, because that would nullify the whole question. Also, many parts can not be mounted on a lathe that will have features to be threaded.
Using dies and taps WITH a lathe that is not good enough to produce threads will usually produce quite sufficient threads. Aligning parts with a mill is also an option.
