Why can I purchase extension cords with triple female plug on one end but can't buy replacement triple female plugs?
Extension cord plugs
Perhaps I don't understand the question, but it seems easy enough to me.
https://www.acehardware.com/departments/lighting-and-electrical/switches-outlets-and-plugs/electric-plugs/3201241
https://www.acehardware.com/departme...-plugs/3407426
https://www.acehardware.com/departme...-plugs/3407848
https://www.acehardware.com/departme...-plugs/3201217
Originally posted by Joel View PostSupply and demand - because there is so little call for them that the price would be so high no one would buy them.
Fortunately triple adapters are cheap enough to solve the issue.
My solution was to buy a three way pigtail and a piece of large diameter Marine shrink tubing and make the connection permanent.I just need one more tool,just one!
- 1 like
That is a SOCKET, not a plug.
The plug is on the other end of the cord and is always just a single for safety reasons. That shock hazard is why you can not buy a double or triple plug.
Originally posted by Michael Edwards View PostPaul A.
- 3 likes
I thought that was meant as well. But it was clearly stated to be a female plug. The correct designation for a moveable connector, AFAIK, is a plug, which can be either male or female. A fixed connector may be known as a socket or receptacle, and also can be male or female.http://pauleschoen.com/pix/PM08_P76_P54.png
USA Maryland 21030
I have a retractable extension cord where I took the bad end off and wired in a power strip in it's place. Open the strip, remove the power cord and attach the extension cord. Now you have a cord with a breaker, surge protection, and a power switch.
- 3 likes
Originally posted by PStechPaul View PostI thought that was meant as well. But it was clearly stated to be a female plug. The correct designation for a moveable connector, AFAIK, is a plug, which can be either male or female. A fixed connector may be known as a socket or receptacle, and also can be male or female.
Are you going to plug a leak in a barrel with another hole ?
-DDZER
They have very little contact pressure, especially as they age.
I have seen many fires (smoldering plastic mostly) from these plastic molded outlets.
Best to have a regular wall mount type receptacle in a metal box.
Ask a contractor/fabricator/carpenter/plumber, anyone who uses extension cords on a daily basis.
Molded receptacles suck.
-DoozerDZER
Paul I don't know about NOW but back in the olden days, 1950s etc, , when I was in the Electronics business, there were "Male" and "Female" PLUGS . Then there were "Male" and "Female"
RECEPTICALS. A plug was on the end of a cable, a receptacle was on a bulkhead or panel . Then to make life a bit more complicated there could be either "PINS" or "SOCKETS" in either male or female plugs or receptacles . So the BIG problem is folks that have no idea of the terminology required to describe an object jump to conclusions in their ignorance . Fortunately ignorance can be corrected by education.. Stupidity is permanent unfortunately . :-)
...lew...
- 1 like
