This is really an update on the Chekko Lathe ressurection.
Now the drive is operational... the motor and countershaft, and the flat belts are functionally tested, it's become apparent that I need to assist the vfd with respect to decellerarion. My little Randa slows to a stop in about 1.5 seconds so I asked the Chekko to do the same, but the countershaft and spindle pulleys, with a combined weight of around 50kg are having none of it. I can stop from around 1000 rpm (motor rpm) but any higher and I get errors. The 10" chuck (not yet fitted) will easily add another 30kg to this.
Quite obvious a braking resistor is required. But... how can they justify the rediculous prices they are asking for what is simply a big resistor?
The inverter spec stated a minimum 75ohm. That's no problem... but the wattage needs to be high. Very high. But how high?
In my scrap bins I found a heating element from an old towel rail. It's rated 600W @ 240V. But how does the 600W equate during braking when the voltages can be considerably higher? Anyway, it measures 93ohm so I figured what the hell?
As a test I connected it, with no heatsink, and got perfect braking up to the max setting 3000 rpm. It got warm, but not hot. With a chuck it'll have to work harder but early results are promising. Add to this the pulley ratio is now wrong as I had to remake the motor pulley at twice the original diameter so the max HZ will need to be reduced to approx half it's current value. So hopefully I'll be decellerating from closer to 1500rpm instead of 3000.
I've made a nice ally heatsink for the element and hope to test tomorrow with the chuck mounted.
Fingers crossed.
Fingers crossed.
