Originally posted by Jonesy
View Post
VFD Braking Resistor
Monarch 10EE 1942
YOu could use 2 of those stove elements by wiring them in series. Here's the rule - 2 equal resistors in parallel equal 1/2 the resistance. 2 resistors in series equal double the resistance. If you were to use 2 equal resistances in series you could use resistors that have half the wattage as each would then be doing half the work.
As it is, you braking resistor seems to be working just fine. If you start/stop often you might want to put a fan near by to get rid of the excess heat.
A caution about heating elements-
they are designed to get hot (duh)
and their resistance increases a LOT with heat.
(I hesitate to say exponentially, but it's an order of magnitude)
So when cold, they are darned near a dead short, and if the braking
circuitry is not designed to load into a dead short, it can overload the
switching devices that apply the load to the bus.
A resistor, however, is designed to increase resistance as little as possible
as it heats, so it's a more 'ideal load'
Added to all the above, it makes good sense that the 600 watt load works
well- since the load never heats up all that much due to a very low duty cycle,
it's presenting an appropriate resistance to the braking circuitry at its 'cold'
resistance, and working well. If it heats up, you may have to reduce your
braking percentage to keep bus voltage down, but nothing will be damaged.
t
resistance may or may not matter. Even if it is futile.rusting in Seattle
Thanks TB. I did hit this element with a heat gun while connected with a multimeter yesterday when trying to decide if it was a goer. I got it hot. Very hot, but not glowing! Didn't see any change in resistance. Stayed within an ohm of 93.
Either way... it's working a treat.
I was stopping the spindle on a sixpence ( a Dime.... for you lot), but as the chuck is a screw-on I've dropped it to 5 seconds.
Need to do a real-world test with the big 4 jaw in situ.Last edited by Jonesy; 01-09-2022, 03:05 PM.
Nichrome resistance varies with temperature increase, but it is not that much.
I still like the rectangular power resistors better since they are designed to be air cooled, have aluminum body with ribs and have provisions for bolting them down. Your heating element is designed to be submerged into liquid for heat transfer. For intermittent use in a machine tool it probably would not matter since your element is oversized.
Originally posted by mikey553 View PostNichrome resistance varies with temperature increase, but it is not that much.
Originally posted by macona View PostHaas just uses range top heater elements for braking resistors on their mills. Cheap and effective.
Unbranded generic high power resistors are cheap enough. But manufacturer specific units are a real con. My manual suggested I use 3 of their units in series to get the right setup. This would cost more than the inverter would (if I'd paid for it).
It does seem there are good cheap effective alternative options for most things in life. I tried to explain that to the wife and she just threw things at me.
