Sounds like a job that I would not want. The issue with the pump setup that you might be pumping sewer water also. How did this get past inspection when it was installed??
OT: Electronics help debouncing a float switch
No inspection required for that - would have been had it been a new drain I would think. The steel that went in as part of the external wall came out was engineered and then inspected.
Had it been inspected it likely would have passed anyway as there are no maps so it would not have been known that something joins this drain.
Well, we've had a camera down the manhole now. Four pipes coming in and even found what appears to be one joining after the manhole. Guess which pipe my toilet is connected to..... that's right, none of them. So it's looking very much like the combined service we have isn't combined at all.
So now negotiations for the costs of digging begin. *Sigh*
Originally posted by Cenedd View PostWell, we've had a camera down the manhole now. Four pipes coming in and even found what appears to be one joining after the manhole. Guess which pipe my toilet is connected to..... that's right, none of them. So it's looking very much like the combined service we have isn't combined at all.
- 1 like
Don't give my wife ideas! .....although, more space for a workshop that isn't a cupboard would be nice...
When we had the sewers lined here, the plumber put down the camera, BUT he also had a sensor unit.... he walked around outside with that, and was able not only to find the pipe and discover where it went, but also was able to determine how far down it is.
Seems like your folks should have been able to do that from your house.. Find one who is. Otherwise there may be a "treasure hunt" all over the place.
In the US, there would have to be a "stack", a vertical vent pipe from the toilet pipe. That would have a "cleanout port", and the camera with sensor compatible head would be fed down that, to follow the drain, and be tracked with the hand-held sensor.
That would probably answer a lot of questions in a "non-invasive" manner. At this point it may be your best path forward, if that is available where you are.4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
"There's no pleasing these serpents"......Lewis Carroll
- 1 like
Originally posted by J Tiers View PostYou must have numpties for plumbers.
That said, we can't get the camera down the line we're connected to (and can't clear the block) so we couldn't trace it beyond where we know it goes anyway. However, it's kind of academic since we know where it doesn't go and that is to the only place it is permissible for to to go - so anywhere it does go is off-limit. We do know where the line from stack to manhole is now that we have found the manhole - a string line should give us that quite accurately and we can dig to meet it and join it. So on paper, it's all easy....it's just getting it done and negotiating who should pay for it. My theory is that it shouldn't be me as it wasn't me who did it wrong in the first place. The builder will want to charge for it despite being responsible for it. However, I suspect that the result will end up somewhere in between. As long as it's less than getting someone else to do it - and it'll be less than taking it legal, regardless. I should caveat that by saying that I want him to do the digging and making good but the actual plumbing part of it ....not so much!
Bob Engelhardt They're quite unusual here when you're anywhere near a grid. Not unheard of but given the main sewer is on-grid it seems more likely that it's a separate rain water service....that we've been polluting. Were there proper maps kept we obviously would not have.
wmgeorge Maybe but it's more a last resort here. It's costly up front, you stand to lose ("I did it in good faith and there were no maps") and even if we win we might just break even. Most likely effect is having to live with it for far longer than if we just got on with it. Sad but true unfortunately.
Originally posted by Cenedd View PostBob Engelhardt They're quite unusual here when you're anywhere near a grid. Not unheard of but given the main sewer is on-grid it seems more likely that it's a separate rain water service....that we've been polluting. Were there proper maps kept we obviously would not have.
wmgeorge Maybe but it's more a last resort here. It's costly up front, you stand to lose ("I did it in good faith and there were no maps") and even if we win we might just break even. Most likely effect is having to live with it for far longer than if we just got on with it. Sad but true unfortunately.Retired - Journeyman Refrigeration Pipefitter - Master Electrician
