Hi everyone.
We heat our home using a wood stove during winter. There is plenty of wood that falls around the house and I am able to chop it up during summer to burn during winter. We have a fairly large Jotul and it can build some serious heat.
However...
I can't help but think that this traditional wood burning design is just horribly inefficient. It takes a lot of wood to heat the house and keep it warm. Most of the heat blows right out the chimey, so the heat going into the room is by way of natural convection and radiation.
One simple improvement could be to blow a fan at the stove to increase the temperature gradient and improve heat transfer efficiency to the room.
But it has got me thinking... could I design my own ultra-efficient heat exchanger wood stove? Essentially, some thick steel plate with heatsink fins, ducting, and a built-in fan. The indoor chimney pipe could have a corrugated shape to increase surface area. This way, the outside of the fireplace itself would be just warm to the touch because the fan was constantly forcing air across the surfaces.
I actually used to own a fireplace with a built-in fan and catalytic converter in the exhaust. It put out so much heat we had to turn off the fan because the house would get too hot.
Why isnt this more common? Cost? Complexity? Are there some safety concerns or something I am missing?
However...
