I have thought strongly about an "afterburner" system. Some would call it a "Smoke Eater".
In my mind, I see a secondary combustion "box" that is located between the wood burner and flue pipe. All the "smoke" from the wood stove must pass through this chamber.
A natural gas or LP gas burner is positioned within the box and in full contact with the "smoke", and unburned hydrocarbons (think creosote).
Secondary air and some sort of "catalytic" hot surface may also be incorporated.
Simple automotive type O2 sensors (heated of course ) and thermocouples would provide feed back to control startup of the auxiliary gas burner.
Of course, a heat extraction devise such as the "Magic Heat" would be fitted to be sure not to send all that additional Techno-energy efficiency up the chimney. Or just send it through a "Russian masonry heater" for heat storage and moderation.;-)
If wood were scarce, I might get started..........
Ash borers have that down to a low priority at this time.
