When I cut aluminum the pieces I am cutting get so hot I can't even touch them. Quite different from when I am milling and taking decent size cuts. I am using a 6 TPI bi-metal blade that is in decent shape, but not brand new. This is on a Grob 24" bandsaw. In the past I cut a bunch of 1-1/4" plate on a 14" wood bandsaw with a wood cutting blade and I don't recall the workpiece getting so hot. I slowed the bandsaw down with the VFD until I got nice chips coming from the cut, and it cut faster, but the workpiece still heats up rather hot. Too much heat is going into the workpiece. This is on 1" thick aluminum.
I have used WD-40 spraying on the blade, but that makes a real mess.
I was wondering about trying a stick lubricant. I have this Cut-Ease from McMaster Carr for $12 and figured I would give it a try.
https://agscompany.com/product/cut-e...nt-stick-1-lb/
I guess the best way to apply this is to peel back the cardboard and just push the stick against the blade, only problem being that with the guides dropped to cut stock there is no way to get the tube against the blade....
The cuts I am making are not tight curves and the 3/8" wide blade should absolutely not be having problems with rubbing.
Thoughts on lubricant and workpiece heating?
