different bits, different speeds
  • #31
    aaaa
    DZER
    • #32
      That chart is about as attractive as looking at pictures of naked dudes.
      -D
      agreed, zero interest in either.
      Guys, this is not a three decimal exercise. RPM = FPM * 4 / Diameter. that's it. Memorize a few common FPM numbers for the materials (work and tool) you use and you can do the whole speed calc thing in your head while you setting up the machine.
      The other thing for beginners to note, is that the resultant rpm is the theoretical maximum. Its the point where going faster disproportionately increases tool wear, i.e. removal rate vs wear is no longer linear. For hss anyway there is no issue (except it takes longer) in going slower. Without knowing that, the beginner is sometimes perplexed; e.g. "how can I drill this little hole, my lathe won't go to 20,000 rpm", etc
      Mcgyver
      • #33
        Just me talking here,
        but the only material I have trouble finding a good
        speed and feed for is cast iron. Too slow and it seems
        to not leave a good finish. Too fast and the tool chatters.
        I think this tricky dance is because, although Iron is not
        very strong (20 to 30,000 psi), it is very tough and hence
        the expression, it wears like iron. So for cast iron, I might
        look up the numbers.
        --Doozer
        DZER
        • #34
          Just to expand on this for the beginner, going too slow is just as bad as going too fast. If you go too slow the cutter rubs and prematurely wears the cutting edge. You really want to be making chips. After a bit of experience, you get the feel for how fast you should be cutting and what good chips look like. I learned the hard way years ago about stainless steel work hardening. Lost a few brand new 1/2" drill bits because I did not keep on the down feed hard enough. (304 is brutal) But even if the material doesn't work harden, rubbing is bad for the cutting edge. So yes, I agree that slower is fine as long as you are making chips that you can pick up and measure the thickness.
          • #35
            To clarify, I assume you mean feeding too slowly, in which case I agree. No point in spinning a million miles per hour and making dust.
            • #36
              You are very correct.
              Stainless steel is actually a good learning tool for doing it right.
              You need to get in there, play hard, and get out quick.
              Like the Navy Seals.
              Good practice really and a good feedback exercise,
              if you are observant and adaptive.
              -Doozer
              DZER
              • #37
                Last time I tried that I ended up married...
                • #38
                  Bah dumb bum ching ! ! !
                  -D
                  DZER
