I am probably going to regret this....
But...
If you watch my Doozer's Shop channel
you know I went to the scrap yard and
got some eye beams for a shop crane
project. They are 5" x 14" eye beams.
Not W-section, not welded. Hot rolled
eye beams. Anyhow I modeled up my
ideas in SolidWorks. The rails (turquois)
are 19 feet long and will be supported on
the ends by 5" x 1/4" square tube columns
on floor plates. The bridge is 24 feet.
The 5" flanges on the bridge are 7/16"
while the 5" flanges on the 19 foot
rail beams are 5/16" . Web sections
are 1/4" on both. More of a girder beam
than a load beam, but I calculated
1/4" deflection with a 6000 pound load.
Anyhow, the wheels I was going to make
from 5" bar stock, a good lathe project.
I was going to use 1"id X 2"od ball bearings
pressed into the wheels, but then I thought
of the bolt on flange bearings might be
handy to mount the 1" axles to the trolley
flanges. The (brown) trolley flanges are
3/8" steel. The (yellow) trolley is 36" long
and made from 3 pieces of 2x2x1/4" steel
tubing. Like trailer hitch material. The
reason I did not use 2x6" tube is because
if I stack 3 pieces of 2x2" tubing, I get so
much more wall thickness, because I am
using it in the "weak" direction, and all that
wall thickness make it very strong for
bending.
As you see, the main bridge beam (green)
is notched and the flanges made to continue
around the notch. This is to drop the
bridge down to save ceiling height. I have
a 12' door opening and 14' ceiling height
so it would be nice to keep this in the
confines of a 2' tall package. The (gray)
5" cee channel on top of the bridge is
extra reinforcement, to help keep the top
flange, which is in compression, from
side buckling.
Any thoughts? Both good and bad?
--Doozer
