As with a lot of threads that are started the OP has a question and there are some good responses. Then there are other replies that are lets just say ridiculous.
To answer the original question, yes, a high performance model engine can be built. It follows the same criteria as their larger brethren, port shape, cam timing, type of induction and exhaust. To build a model engine and get it to work is in most cases challenging enough without adding in all the elements of high performance. A model engine is made to replicate an existing engine whether the end result being a static model or a functional one.
Can a model engine be used to power a weed eater or chain saw, absolutely, but why? Are you going to post handbills telling people that at 3:00 on Friday you're going to be using your model V-8 weed eater?
Can machinists who create model engines hold exacting tolerances? Most assuredly. Look up Lou Chenot Deusenberg and then tell me that model machinists are hacks.
gbritnell
gbritnell
