I thought I read that they are around $60 to $120. Not sure why so high. There appear to be two manufacturers, so that accounts for some of the price differential.
Dan
I thought the guy in the vid invented them, so to speak.
In my firefighting days a old butter knife was our go to for a lock out. If things got serious the ax and haligan bar would open almost any door in seconds. Lock picking is not hard if know what you are trying to do. I played around with some picks when a fellow fire fighter took a locksmith class. We just had too many easier ways to break in.
New York City locksmith here, I definetely second that statement. There are usually two or three other ways than picking to open a door non-destructively. As far as real lockpickers go, I'm not very good. I do well with bump keys and our other tools. Rarely do I ever have to drill a lock open. That's a real last resort, although for a lot of "emergency locksmiths" in my part of the country, it's their plan A. We do far more repairs and instalations than lock-outs. Like today, we changed a floor check, repaired a safe we cracked the day before, changed some locks in times Square, and
had just one lock out (although that was the only one that paid same -day) .
As for lock picks, it would make sense to make several yourself that are the right thickness and shape at the business end. Especially for a situation when you must reach for a short pin behind a long pin. Lock picks are still pretty expensive even through my distributors.
it was a dorma bts 80. A sticker on the closer said it was installed in 2017. a Rixon usually lasts longer than that. I haven't replaced any I originally installed yet. although last year we did a 27 and a 28 where it just locked up about 20 degrees from closed and would not budge untill we put a cheater bar on . they got replaced of course.
The 27/28s we had some links that did not get spin riveted all the way.
I kept telling the manufacturing engineer to fix the fixturing on the
rivet machine because it was so worn and loose, and the links
would move around. Instead he just made the recess in the tip
of the riveting bit deeper so it self centers on the pin. This was
no good because it swedges the link and not the pin. Half azz fix.
Then he bought another Bracker rivetting machine, and never
got new fixturing. It sat for a few years and then they took it
to the warehouse for cold storage. They are still using the old
worn out rivetting machine, with a foot lever that applies the
force to move the ram. No process controls. Same sloppy
fixturing. I told the mfg engineer to make the rivet bit out of
heat treated S7 tool steel. No. He just keep re-grinding the old
one and it is worn to a nub. The links still look like shlt and
no one cares and we still get returns. Happy day.
Dan
Two reasons for high prices on the Lishi tools. Small volume might mean high cost per. Charge what the market will bear. Profit per item might be high but volume very low.
The lishi tools for auto locks are lower in price even though they're clearly more complicated to make by the nature of the two picks having to slide around inside that keyway shape.
The picks for schlage, kwickset, etc are priced higher because they know they'll sell. I remember a few years ago when they introduced the Schlage pick, the automotive picks were aound $30 and the Schlage was $120. And that was the price to the trade at HL Flake. It is a money maker though so you can't complain too much.
Yes. The picks I made are stainless steel and high quality. Making a bunch of blanks is a big $ saver. I will use shrink sleeve to wrap them with. I've also tried most other methods. Picks break so I'm not going to invest (any more 😬) in fancy handles.
I used a side grinder with a fine kerf wheel to cut kerfs into the top and bottom where the metal gets removed and then removed the rest with an air file. The stacking, cold shop and the method used kept the heat low. I finish each one individually and the tip of the 12" air file is perfect for the curve of the hook.
That's the good news.
The bad news is that I still can pick my way out of a corduroy prophylactic. Yesterday I got 14 quality lock cylinders for $18.00 for practice from the local mega resale store. These were added to the psycho number of practice locks I already have. I still have almost zero success with picking locks. I've watched enough youtubes to where the phosphorus is damaged by the YouTube logo.
For some reason I feel that getting more, or upgrading, equipment will make success easier. So far this hasn't worked out. I'm probably $150.00 in with supplies and the poor soul needing me to get them out of a burning building is ashes. Maybe I need an apron with "lock picker" embroidered on it? 😬
