The Dremel chamfer tool reminded me of a question:
How to put those perfect chamfers on parts as seen on many tools? Obviously not with a chamfering tool like the Dremel tool, since they often got down into inside corners, etc, places where even a 45 degree endmill won't do it.
I'm talking about the perfect, even, chamfers on all edges of some tools, despite odd angles. Chamfers with perfect meeting lines, on both inside and outside corners/edges. They look like a nightmare to get done to the perfection seen when turning dials, but in many cases are on parts predating common CNC use.
At what stage are they put on? As the part is made. or afterward? Seems as if it has to me as it is being made,since setup would be a killer otherwise.
What tool is used? 45 degree end mills, I think, which I have none of at the moment, but some locations obviously cannot use those, and seemingly must be done with regular endmills at an angle.
Any tips on getting the widths as perfect as they generally are?
