So you find you could use a Steady on rare occasion, but they don't go for chump change.
A discarded (Jeep) ring gear to the rescue. You do need to throw it into the woodstove for a
couple of days before attempting to machine it.
Meanwhile, make a V-base applicable for a Clausing 5900 and an under-way clamp plate with
stud projecting up thru V-base to the ring gear. Then weld an appropriate-height mounting
pad to the ring gear with 1/4" plate. Allow a pocket for two bolts down into the V-base. And
a center nut to pull up the clamping stud. 5/8" threaded arms/locknuts, or a more elegant
design of your choosing.
Theoretically, the ring gear portion is easily re-adaptable to another lathe via a new base block.
And no, don't use it enough to have bothered with a hinged or bolt-opening feature.
