Originally posted by wmgeorge
View Post
OT: any steam heat wizards here?
Originally posted by SVS View Post
So What!….. You’ve thrown three tantrums, said you were done with this thread, and now you’re giving updates like a tattling four year old…..Retired - Journeyman Refrigeration Pipefitter - Master Electrician
- Likes 1
Originally posted by wmgeorge View Post... Everyone is waiting for the professional testing to be done and a report... except for you. ...
I'm sure that plenty of us were hoping this thread would just die. We were given hope of that in your post #74: "Please post here when you get it fixed, because I am done wasting time on you ..."
- Likes 2
Originally posted by Bob Engelhardt View Post
"Everyone"? I don't think so. I don't think anybody else gives a damn.
I'm sure that plenty of us that were hoping this thread would just die. We were given hope of that in your post #74: "Please post here when you get it fixed, because I am done wasting time on you ..."
I'm sure that plenty of us were hoping this thread would just die. We were given hope of that in your post #74: "Please post here when you get it fixed, because I am done wasting time on you ..."Retired - Journeyman Refrigeration Pipefitter - Master Electrician
- Likes 1
a little late in the discussion but does this type of system use steam traps that hold the steam in the radiator until it condenses and then they open to return the condensate back to the boiler? If so is it possible that it is just letting the steam pass through one or more of the radiators not allowing it to ever build up pressure, which would occur if the trap was malfunctioning. I am not real familiar with residential systems but fairly conversant with industrial boilers used for tank/process heating in a anodizing shop. Jim
Originally posted by jmm03 View Posta little late in the discussion but does this type of system use steam traps that hold the steam in the radiator until it condenses and then they open to return the condensate back to the boiler? If so is it possible that it is just letting the steam pass through one or more of the radiators not allowing it to ever build up pressure, which would occur if the trap was malfunctioning. I am not real familiar with residential systems but fairly conversant with industrial boilers used for tank/process heating in a anodizing shop. Jim
Jim, No its a simple old one pipe low pressure steam system. Put in years and years ago and updated in 2012 with a oil fired boiler that was switched over to gas at the same time. It relies on less than 1 lb or perhaps a bit more or less of steam pressure to take the steam to the radiators. Very sensitive on piping as the water condensed returns in the same piping to a point by the boiler where the pressure in that return line takes it back to the boiler. The magic number is 28 inches of water height, which is 1 psi gauge. The vents in the radiator control the steam coming into it by either venting or closing. No traps like a two pipe system you and I have worked on before.
Sensitive to the returns being piped properly and the sludge kept out.
When we shut down our steam boilers we always blew them down to clean out the mud and sludge in the bottom.Last edited by wmgeorge; 01-26-2022, 03:15 PM.Retired - Journeyman Refrigeration Pipefitter - Master Electrician
- Likes 1
Taking bets on THIS system?
Once again if this Thread is annoying to you please scroll on by.Retired - Journeyman Refrigeration Pipefitter - Master Electrician
- Likes 1
Christ this thread has become a ****show with Mr George thinking he vanquished me from the site with his unwaveringly wrong advice. I don't know where anyone got the idea I had a tech coming Friday, I had to take my 88 year old mom to the hospital for tests, and it felt so good to be away from this mess I stayed away.
As my stalker already knows (it's bad form to dox someone's username on a different site, privacy and all that) I finally gave up on getting a tech, bought a boiler brush, and cleaned the damn boiler myself yesterday. I didn't dare mess with the burner. Result: Flue temp is 340 down from 400, and rooms that were cold are at setpoint. I still need to get the combustion checked and burner cleaned, but at least my tenants and their baby aren't cold.
Of all the commentary on 2 sites, no one said "a sooty boiler can reduce your heat significantly, try cleaning it yourself". Most of the comments on the heating site were to balance the venting, like you can get 2 full cups of water by pouring some from a 3/4 full cup to an half empty one! It appears my gut was right. It should be, the damn thing is big enough.Location: Jersey City NJ USA
- Likes 3
Originally posted by gellfex View Post.................................................. ..
Of all the commentary on 2 sites, no one said "a sooty boiler can reduce your heat significantly, try cleaning it yourself".......................................
. Item #1 in post 117 is one mention of the "insulation" due to soot. I am pretty sure one or two others mentioned it also.
If you are producing soot with a gas burner, you have a potentially lethal problem. Lots of CO there. Not enough air for complete combustion. Probably dirty fan or air inlet.Could also be flame impingement. Seriously get a professional to take care of it. Brushing off soot did not take care of the problem. You do not have the tools or training to solve the problem. The advice you get on this forum is worth what you paid for it.
- Likes 1
Yep, probably CO generation, poor economy, etc.
Poor economy costs money. CO has potentially higher costs. And there are other issues as well when things are not done right.
I lived in an apartment where (as I found out) the landlord did the boiler maintenance. 7 unit apartment, I lived in the one that was partly over the boiler.
One fine morning there was a dull noise and my floor jumped a bit.
I went down to the basement to see what was up. The gas boiler had apparently had a late ignition, and had blown the door out of the boiler room, as well as dislodged some concrete blocks in the wall of the boiler room, and blown off the door of the boiler itself (it was a converted coal burner). Could not see if the flue was dislodged, but it looked possible. I went to the electric service and pulled breakers until I got it shut off, then called the landlord. I was not happy, and neither was he after the call.
That one could have ended badly.
Don't be "that guy".
- Likes 2
Originally posted by deltap View PostIf you are producing soot with a gas burner, you have a potentially lethal problem. Lots of CO there. Not enough air for complete combustion. Probably dirty fan or air inlet.Could also be flame impingement. Seriously get a professional to take care of it. Brushing off soot did not take care of the problem. You do not have the tools or training to solve the problem. The advice you get on this forum is worth what you paid for it.
Obviously I need a new steam tech. But weather like this makes professionals very hard to get for a system that is working marginally vs all the calls they're getting for systems not working at all.Location: Jersey City NJ USA
The advice given here is based on the information you posted. What advice have I given that was wrong?
You seem to change your story all the time. You have told us the boiler was professionally cleaned and combustion checked and adjusted last March? True or false?
But From above you posted: I'm doing self-help is because the steam tech who came, who's actually highly regarded on the heating site, did not do a combustion test.
You stated here you had a Tech coming on last Friday and I can post a screen shot reminder... If you forgot. True or false?
Now you state you took your mother to the doctor last Friday when In fact you posted elsewhere you were working on the said boiler and taking the flue temperature?
Which is it, seeking the Truth?
BTW When you post on the Internet, on a public Forum, it will be indexed by a robot and Google will pick it up in minutes. Who's the Stalker... turns out it was Google!!Last edited by wmgeorge; 01-27-2022, 11:04 AM.Retired - Journeyman Refrigeration Pipefitter - Master Electrician
- Likes 1
