Originally posted by Randy
View Post
Mickey, I have to admit that I "assumed" that the top was flat and parallel to the spindle. And we know how that goes
I've bought a bunch of holders for my own QCTP. But I know I change them on occasion so having a checker that doesn't require me to remove the work from the chuck is preferred. Plus for the bigger boring bars the QCTP comes off and I go with my home shop made bars and post. And those bars are frequently moved to alter their extension to suit the job. So they need to be checked when that is done. So the height checker gets used more frequently than having a QCTP would suggest.
Mr Whoopee. I love the spring loaded swing away top plate for testing against the tips being too high. I was wondering about fitting such a top plate to my short gauge. I'll be copying what you did with the spring regardless of it being your idea or not.
EDIT- Mickey, did you clean up the lathe for the photo shoot? I scrolled up past your pictures again and noticed that there isn't a single spec of swarf even in the corners! Or did you buy a new lathe just for the pictures?
