Originally posted by elf
View Post
Angular Contact Bearing mount
Originally posted by elf View PostThe mounting bracket for my ballscrew angular contact bearings has the bearings separated by 15mm with only the outer race supported:
I think this defeats the purpose of the angular contact bearings and regular deep groove bearings would work as well if a spacer was added to support the inner races. What say you?
I didn't read all of the above link but one important thing to consider is the ratio of axial load to thrust load. You have redial bearings that will take no thrust load and thrust bearings that will take no radial load, and a whole slew of bearings in between that will take some combination of both i.e. angular contact bearings or a deep race bearing. among many others. Your application will determine just what you need as far as the radial/thrust ratio.
lg
no neat sig line
