Originally posted by Doozer
View Post
This is the reason I cannot advocate towing with the driveshaft disconnected. Much like Tim Clarke noted in his post, internal transmission damage is inevitable when towing long distance.Tim has spent decades servicing HD trucks so I believe he is very qualified to make the statement that he did.
These precautions are not so much for short durations as there would likely be enough residual oil left to not do any harm. How long of a tow is too long?
Well that's anybody's guess.Do you feel lucky?
I would not like to see someone here have to pay for a suggestion that no harm will be done internally. But like I say, it depends on the transmission in question, and although I've had MG Midgets and TR's is the past I did not flat tow or have a look at the internals of those gearboxes so I like to err on the side of caution, always cheaper that way if not always convenient.
Regarding bigger truck transmissions, yes they do not have or need a tailshaft housing but they do have an output shaft that is subject to the same constraints and consequences as many smaller ones, internal damage when towed with the drive wheels spinning the output shaft of the transmission.
Look at any Eaton/Fuller transmission owners or service manual and it is one of the first precautions listed in bold type.
CAUTION
When towing the vehicle, the output shaft of the transmission must not be
allowed to spin or turn. If the vehicle is towed with the drive wheels still in
contact with the road surface, the vehicle axle shafts or driveline must be
removed or disconnected.
WARNING: Serious internal transmission damage can result from
improper vehicle towing.
