Hi Group,
I have a fitting that is not available except by one vendor and their cost ($30.00) is more than I'm willing to lay out when I think I can make the same thing... The drilling, threading and machining is something I feel ok about. It's' the flare bulb in the bottom that I'm not sure how to make.
The hole is threaded and has a double flare bulb in the bottom for the brake line fitting to seal against. How would you drill this hole to get the proper Major Diameter to thread the inside and cut the bulb in the bottom.
It screws into the wheel cylinder and has a banjo fitting that aligns with the hole in the side for a bleed port and the brake line fitting screws into the hex end with the Double flare bulb in the bottom.
I look forward to any help that you can provide.
TX
Mr fixit for the family
Chris
TX
Chris
