Just a FYI for folks with a Mini Split. I installed my Mitsubishi nearly 3 years ago and no issues until last summer. Had to replace a split flare on the liquid line and recharge with R410a. This fall we had beautiful weather and it still did fine, not much air flow but Ok. Now a few weeks ago it turned into a real winter!!! Still Not much air flow and very low heat output. After checking the charge level and topping off a bit, no improvement. Pulled the cover off the inside unit.... the squirrel cage fan vanes packed, and full of Dirt!! In spite of keeping the filter clean, washing every couple of months.
Cleaned the fan blades with compressed air, yes a mess on our 4 season porch. But Wow what a difference!
I have some filter coating spray to use on the filter that washes out with hot water, I hope that helps. I understand this is an ongoing issue with the Mini splits.
