Originally posted by Tundra Twin Track
View Post
As to how the spindle brake works I have no idea. I did take the power draw bar off once because it didn't seem to be working right, but it turned out to be me not using it right. Other than that I have not been inside the machine. There is a lever on the side of the head. I push it back and it kills power to the spindle motor. Push it back further and it stops the spindle very effectively.
FYI: It came stock with a 7.5HP VFD to drive the 5HP spindle motor.
As to the new tech old tech thing.... It wasn't that long ago when it was hard to find 1-3 VFDs rated for full 3ph power at 1-3ph input. Even now when I look them up they tend to be more expensive than an upsized VFD. The problem is most 3-3 units over about 3.7Kw (5HP) are not advertised for 1-3 phase converter operation. You have to dig into the manuals to see if they are capable or not. As an aside, I've got a bunch of machines running VFDs and when I first started doing this PolySpede/Spedestar was the only 1-3 I found rated for 1-3 at full rated power. I was going to put one on the Hurco mill, but I just haven't gotten around to it. I just keep running the 3.7Kw derated Mitsubishi that was in i when I got it. I will upgrade it at some point. The Mitsubishi is limited at 120hz in the menu, and I want to be able to run upto 200hz. When I upgrade I'd like to also be able to get full power. Those machines were run at 200hz with a pricey upgrade from Hurco. From what I have heard talking to guys who had them upgraded back in the 80s and 90s all Hurco appeared to do was upgrade the electronics. Not the spindle.
