So, in between sessions of rearranging things and putting away stuff, I checked the little 4 way post. It will need to be raised slightly to put it on-center for toolbits. I never bothered to look at it much as I did not have a slide to hold it.
I also found out that it is all-metric (no surprise). It is set up to use 3mm tool blanks (which I have none of), so the 1/8" I have will not fit the slots. I can mill them to fix that, and can still use 3mm if I do that.. Also, there are not enough screws. Turns out it is set up for M2.2 x 0.45 screws. "Almost" a #2-56, but no cigar. Naturally, I have no dies for that size, I only have M2.5 x 0.45.
So, some stuff to get, and things to do before I can use the 4-way. I can use one of the lantern toolposts any time, though
