Cheapo slitting saw
  • #16
    It worked pretty good for a while on steel then it started spitting teeth. I took it out hammered it flat and ground the rest of the carnage off. Went real slow and finished the job.
    • #17
      Well that explains it. I was wondering how it got so hacked up on one side. You could always bring it back and tell them it didn't work.
      JL.....
      • #18
        I'd run those slower, but with some more feed. That is SOP with a horizontal mill, but seems to get forgotten with a vertical mill...... and some of them just will not GO slower.
        If it was spitting teeth, did the silver solder melt? or did they just tear off/out?
        • #19
          Now that is a VERY good question.
          I run slitting saws in the CNC, but I do NOT try to do a deep cut. Instead I run multiple passes at 1 mm depth in Al or 0.5 mm depth in steel, and at low feed and low spin. There is a reason. Saws below 0.5 mm thickness are usually treated even more gently.
          When I make the first quite shallow pass the blades stays stiff and cuts straight. Just what I want. The second pass is then guided by the first pass, and so on. The whole cut ends up very nice and square. I use an air blast to clear the chips (avoid jamming), but often no lube.
          Of course, the other thing with doing it in a CNC is that I can sit back and snooze while it does its multiple passes.🤗
          Cheers
          Roger
