Making a rotary vane compressor
  • #31
    Appearance is not everything. Quite a few ball bearings I have looked at had finishes in the grooves that "looked" rough and scratched, but the bearings were quite good in operation. So obviously the finish was a lot smoother than it appeared to be!
    Appearance is everything actually. If when light is put on a surface and you see deviations albeit small the surface is not flat and smooth. Maybe you can't feel the ridges with your finger but that isn't really a good test in this application. In my opinion at least. Some of you fellas that are lots smarter than me might disagree maybe but in my Cowboy logic I think it is true. Not a valid comparison between ball bearings and a flat surface in my book. My take on flat and smooth on compressors comes from hands on experience with many vane and screw compressors used in my business in Texas. I also don't think a bore that is turned only and not honed will be OK in this application. At least it won't be efficient.
    I ain't watchin your videos Finn.
    • #32
      Originally posted by FinnoUgric View Post
      I have now started to make a lamellar air compressor.
      As someone will eventually ask: Why? The answer is simple: Because I want to MAKE it, not to BUY it. I am also oddly obsessed to rotating machinery.
      It will most probably become a semi failed unit but still there will be a lot to learn during making it.
      Very cool!! I like this project... Ill keep watching in silence
      Oh? The vids and animation, no problem. Your post, your content. If someone choses not to learn or watch it that would be their loss, not yours. (you didnt dip into my pocket for loose change while I was watching did you JR
      • #33
        I think it depends on the material of the lamelles. If the lamelles are made out of something relatively soft material like teflon, it would probably not be a good idea to rub them against anything rougher than a mirror surface.
        In this appliucation, however, the lamelles are made out of some relatively hard material. Definitely harder than the cylinder. There will be oil which futher enhances the sealing. I hope it squirts out more air than oil 😆
        I will be the first person to admit my mistake and bend over to hone that "darn" cylinder when it comes to that. The construction allows it to be done at a later time if need be.
        If I would try to get cheese on top of my sandwiches with my videos, that might offend me. However, I am not trying to be popular or earn money here. I try to be myself with all my mistakes and ever so strange ideas. Most importantly I try to be honest. Internet is alrteady bloated with fake things and I try be a tad different. I actually appreciate Your honesty.
        • #34
          How to make six grooves 3 millimetres wide and 15 millimetres deep?
          You could try to make those with an endmill but since the grooves are 100 millimetres long that would be a major PITA to pull through.
          The obvious answer is, of course, the humble slitting saw.
          Traditionally I have had no luck whatsoever with those and usually I end up collecting slitting saw shrapnel from my floor.
          It will be very exiting to see what is the outcome this time.
ID:	1995887 Click image for larger version
ID:	1995888 Click image for larger version
ID:	1995890 Click image for larger version
          There is also a video here.
          • #35
            This time it will be the lamelles for the compressor.
            There are 6 of them and they are made out of Uddeholm Vanadis 4 tool steel.
            This steel is quite tough to machine and there are also some challenges with setups.
            I will also get a stopping reminder why safety goggles are a must.
ID:	1995894 Click image for larger version
ID:	1995893 Click image for larger version
ID:	1995892 Click image for larger version
ID:	1995895 Click image for larger version
            The associated video is here
            • #36
              That's some really cool work. I especially like the last picture
              • #37
                Yet another steel puck for the compressor
ID:	1997375 Click image for larger version
ID:	1997373 Click image for larger version
ID:	1997372 Click image for larger version
                There will be a precision recess for a shaft seal.
                I will be using my Wohlhaupter UPA3 boring head to make that one.
                The challenge here was to have the recess for the shaft seal accurately placed and dimensioned.
                • #38
                  Have to say, the intro is “different”
                  • #39
                    Will this compressor become silent?
ID:	2001689 Click image for larger version
ID:	2001688 Click image for larger version
ID:	2001687 Click image for larger version
                    Air enters and exits the compressor through holes in the cylinder walls.
                    I machine flats on cylinder sides and holes for air flow.
                    Then I put the thing temporarily together and test it.
                    • #40
                      The output manifold is just a block of steel with three holes and a recess.
ID:	2002206 Click image for larger version
ID:	2002205 Click image for larger version
ID:	2002207 Click image for larger version
ID:	2002204 Click image for larger version
                      Although it is so simple, I manage to make a major mistake with it.
                      I am lucky enough to catch the mistake in time and take corrective actions.
                      In this video I am using:
                      - Schaublin SV-51 (1955) Milling machine
                      - Solberga (1975) Drill press
                      The video is here
                      • #41
                        Click image for larger version  Name:	Forumshot04.jpg Views:	262 Size:	395.9 KB ID:	1995892
                        You might have trouble reselling that, even on eBay...
                        "CONDITION - USED, some wear, see photo. "
                        • #42
                          The input manifold is yet another block of steel
ID:	2005162 Click image for larger version
ID:	2005163 Click image for larger version
ID:	2005161 Click image for larger version
ID:	2005160 Click image for larger version
                          Milling a deep pocket in steel can be an ordeal in a manual machine especially if the steel is tough.
                          I present a method of making a deep pocket that does not require chip removal by high pressure flood coolant.
                          The video is here
