I have an air vent that is leaking water:
The leak is "under" the adjust knob - most likely the gland sealing the shaft. Of course the knob is frozen or I'd just close it. If I force it I'd likely make things worse - BTDT.
There are no isolation valves for the zone (what were they thinking?), so I'd like to put a band aid on it until the heating season is over. I've thought of a couple of things, but I'd like to hear if they have been tried and failed before I go through the try and fail myself.
My first thought is to use that self-fusing (self vulcanizing) tape - it's non-adhesive and sticks/seals to itself when it's stretched during application. It's made to seal leaky pipes, but this is kinda extreme. A hose clamp around the tape? There's pressure in the system, but not that much - 15psi?
Another thought is to fashion a dam around the vent and fill it with hydraulic cement. The stuff works under water & expands as it cures. But not against pressure?
Epoxy is not going to adhere to wet & pressure, is it?
Anybody had this problem & found a work around?
Of course I could just turn down the thermostat on that zone, let it cool off and work fast to replace the valve "live" (under pressure). Sure as shyt the vent would break & I'd be up to my neck in it.
