I have a Rusnok vertical head on my Vernon. It needs to be trammed like any other vertical spindle & bump-adjust gets me where I need to be. But it could be more convenient, especially when I have it angled 60* & its center of mass is way off the over-arm axis:
So I made a fine-adjust for it. First I took took a right angle drive that I got at the dump years ago:
And cut it down to the useful parts:
I cut the worm gear off its shaft & bored it to the over-arm diameter (2"). Slit & put a tightener on it; and made a crank for the worm shaft:
Installed on the back of the mill:
It does have to be loosened to adjust the over-arm in & out, but that's no big deal (when the head isn't on it).
