Chris, it just occurred to me, something I've done for a temporary reference mark is the good ol' sharpie. Wipe it off to re-set.
Any compound slide dials that have a zeroing feature?
Hi Group,
All great suggestions. I didn't make it into the shop today, family (grandkids) showed up so the day was devoted to that vs the shop.
I recall that the inner dial does not have any setscrew like the cross slide does. I too have put slotted screws in the cross slide to zero. I'll take a look at the collier again and see what I can do to the star knob to modify. I just wasn't sure this was a one off, or lathes came this way, now I know this is a one off for sure.
TX
Mr fixit for the family
Chris
That is obviously not a SB OEM knob and scale. But I can't think anyone would make such a nice looking knob and scale that was not settable to zero it.
The first thing I would do would be to soak it in penetrating oil and come back the next day and see if the scale will rotate while you hold that fancy knob.
If that does not work, then disassemble it, probably by unscrewing that nut in your photo, and see just how things work. I would bet that it can be reassembled with some light oil and care in tightening things to have an adjustable scale.Paul A.
How many years and models did SB produce the 9 for? It might well be that a non adjustable index was how it came at some point. The trick now will be what it takes to turn it into an adjustable version. Because having the ability to zero it during a fairly wide range of compound based operations has been a pretty handy feature. I know I would not want to be without that feature.Chilliwack BC, Canada
It could be something simple like shimming the knob away from the dial. The dial is most likely being held in place by friction only from the knob pressure. This setup was someone's effort to give himself "big dials" on the 9" compound. Normally, the 9" compound had dials about the same size as the cross-slide dials.
Or it may be that the dial is part of the "stackup" for preventing backlash, and is too tight.
The Logan was like that, so I bored out the dial (I only did the crosslide, but could have done both), and made an extended nut to fit the bored out dial and let it turn without affecting the backlash adjustment.4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
"There's no pleasing these serpents"......Lewis Carroll
Originally posted by Randy View PostChris, it just occurred to me, something I've done for a temporary reference mark is the good ol' sharpie. Wipe it off to re-set.
Sharpie works great for this sort of thing. I do simple layouts on my steel top roll around and mark stuff, write down numbers, etc. on my machines all the time.
Originally posted by strokersix View Post
^^this
Originally posted by Randy View PostChris, it just occurred to me, something I've done for a temporary reference mark is the good ol' sharpie. Wipe it off to re-set.4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
Originally posted by SLK001 View PostIt could be something simple like shimming the knob away from the dial. The dial is most likely being held in place by friction only from the knob pressure. This setup was someone's effort to give himself "big dials" on the 9" compound. Normally, the 9" compound had dials about the same size as the cross-slide dials.
Or perhaps there's an O ring drag tensioner? If so it might just be gummed up? Or the other option I like is the stack up isn't done correctly and it's just pinched.
Regardless though, we're all machinists here. This is very much a correctible situation. All shall be revealed when Mr Fixit pulls the compound apart and analyzes the parts.Chilliwack BC, Canada
The Rivett has no screw in the dial, but is resettable. It has a similar looking (knurled, though) screw in the end of the shaft, with a point on the tip. The point forces outward a small "shoe" set in the shaft to lock the dial.
Much "cleaner", and no tools needed to set.4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
Hi Guys,
Haven't been out into the shop tonight but since there are questions, I went and took the dial apart before turning in for the night.. It looks like it has been made for a couple of reasons. The first is it is all one piece, the numbering on the dial are not very straight in line. There was a set screw that I did not look for or see that held the reference mark ring for the dial mounted on top of the original reference mark dial half. So It looks like it was a custom dial and all I need to do is find or make a number dial and hand wheel to use it like original. At least that's the way I see it, What say you??
TX
Chris
I say you are correct. Now another option may be to part the number collar from the knob. Add a setscrew to the number collar and figure a way to attach the knob without binding the collar and you would be good to go at almost no cost. You already have a lathe to part the collar with 😂.Robin
Happily working on my second millionGave up on the first
