Originally posted by Randy
View Post
Any compound slide dials that have a zeroing feature?
compound? On my compound I just use it for threading. So I use a dial indicator mag attached to my cross slide. JR
P.S. You should like to use the plunger of your indicator on the face of the item you are measuring.
In this case the face of the compound or even behind it if its a big lathe. Always place the movement of the piston of the measuring device perpendicular to the movement of the tool. For best results. JR
Originally posted by oxford View PostI’m pretty surprised that someone was able to make that dial/knob combo yet didn't see the need to have the dial zero-able."it is no measure of mental health to be well adjusted to a profoundly sick society." -- krishnamurti
"look deep into nature, and then you will understand everything better." -- albert einstien
"any intelligent fool can make things bigger and more complex...It takes a touch of genius - and a lot of courage to move in the opposite direction."
Originally posted by mtraven View Post
perhaps they saw the need to not have the dial-zeroable? I can't imagine why, but on a part that well made, I have to think it was intentional.
Hi Guys,
I agree it was either because it was missing the dial and they had this dial or they thought they were improving things, which I find hard to believe. I have been using it the way it is for quite a while, but doing some internal threading for the first time I needed the dial to zero for me to keep track and it wouldn't so that started the question. I'm working on another project at the moment, but when I'm done with it the next is to rework the dial to be able to zero like the cross slide, hopefully with a new handle too. I probably will have to make a ball turner first. LOL.. A tool for a tool situation again..!
TX
Mr fixit for the family
Chris
