I had to make an M2.5 set screw about 2mm long, when I was refurbishing a small crosslide for a jeweler's lathe. The old one was stuck and had to be drilled out. The tool and method may be interesting to anyone else doing that.
I have pieces of angle iron that I can hold in a vise, with threaded holes for holding screws. This one has threaded holes in it from M1.6 to M3.
So, I put an existing longer (salvaged) screw into the appropriate hole, from the bottom, sticking up off the surface. Then while holding that from turning, I filed the end flat, then used a small saw (X-Acto in this case) to put a slot across the end, keeping it in the middle.
Once that was done, I took out the screw, put it in again from the top side, and screwed in as far as the length I needed, plus a bit. Holding the head with a screwdriver, I cut the screw. It was hardened, and I had to use a small triangular file from each side, then broke off the screw. The excess was filed flat, and the screw was backed out using the slot, so as to remove or flatten any burrs. The resulting screw went right into the hole it needed to go in.
Here is a picture (not too great) of the angle plate for these metric screws. No big whoopee, just a piece of angle with tapped holes in it, each marked with size.
