I want to buy a set of inside lapping tools.I am confused on what kind to purchase. I don't anticipate going over 1/2". I see barrel laps and blind laps advertised. I know what each is intended for. Can I buy the blind laps and use them for through applications also? So far it seems that Travers has the lowest price. I also see that American Lap has quite an assortment, but no prices listed. School me on what I should be looking for, to get the most bang for the buck here.
Lapping Tool Info Needed
From someone who doesn't do *that* much lapping: Yes, you can use a blind lap on a through hole but the tool movement has to be a bit slower than with a through lap as the blind lap expands more at the end than in it's middle. I use Timesaver's lapping compound with my brass laps - they don't embed and break down in the process so I don't have to keep multiple barrels for the different grits. That being said, if I have a lot of one size of hole to do at a particular size I'll charge a barrel with a grit and go at it that way as it's a little bit faster and somewhat more predictable in removal rate.
For really small holes I use midget laps (split wire laps), then copperhead laps. Somewhere above 3/8" I use brass expanding laps.
