Help with qctp picture
If you want to know how it works, that is pretty evident from a quick look at the parts.
A reasonable system, if perhaps a little less than the "Q" part of QCTP.4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
"There's no pleasing these serpents"......Lewis Carroll
Originally posted by richz View PostI found a picture of this qctp on Pinterest. It references this site. Would it be possible for some to help me find the original posting?
https://bbs.homeshopmachinist.net/fo...-tools/page106
George
Traverse City, MI
Not trying to go off topic here,
but Q? Does anyone know what
a Hardinge HLV quick change tool
post looks like? They have a side
and a front dovetail and the locking
elements is in the corner, and will
lock a toolholder in either position.
It is a tee nut of sorts, tightened
by a draw screw, diagonally through
the body of the tool post. Much like
the pictured above, but diagonally.
It is super simple, with just 2 moving
parts basically. It is just a bit smaller
than the AXA size. I wonder why
no one copies the Hardinge tool
post design? Some copyright issue?
Surely it has expired years ago.
I am half tempted to measure it up
and draw it in Solidworks and post
it here, if there is no legal issue
to do so. What do you all think ? ? ?
--Doozer
DZER
Originally posted by George Bulliss View Post
https://bbs.homeshopmachinist.net/fo...93#post1228493
[QUOTE=Doozer;n1982993]Not trying to go off topic here,
--Doozer
Looks like an interesting design. I'm sure that if there was patent protection it's long since expired.
Aloris won the QCTP design contest for the same reason that Microsoft won the OS contest.
I have no idea what that reason is.It's all mind over matter.
If you don't mind, it don't matter.
Originally posted by MrWhoopee View PostLooks like an interesting design. I'm sure that if there was patent protection it's long since expired.
I don't like the method this post uses because it causes a hinge. The fairly narrow dovetail key is going to pull the holder into the flat surfaces and away from hard contact with the fixed portion of the dovetail. And that will cause it to loose registration pressure with the actual dovetail. At that point it will permit the tool holder block to hinge cutter down until it touches the fixed dovetails at the top of the rear and bottom of the front dovetail.
If you want to make a post of this style you'd be far better off with the MLA style where the whole dovetail post is split and wedges the holder for the whole height of the dovetail in the holder.
For the same reason the MLA style is better than this one the wedge style Aloris design is better than the center ram style Aloris design. Namely that the dovetail is locked hard for the whole length.
That Hardinge design is still not a two sided wedge lock. But it at least pulls one side of the dovetail solidly into lock. So I'd say it's a lot better than the full dovetail key shown in the opening post.
Originally posted by Doozer View PostNot trying to go off topic here,
but Q? ..................... ? ? ?
--Doozer
The "puller" appears to be in the middle. It apparently pulls the part either into the front of the dovetail, OR against the main part of the post. Either is in principle no worse than a piston post.
I agree that the wedge post is likely better, but it is better than the piston post as well. Almost every post aside from the wedge relies on some form of tension and resistance to bending.
AND, if you look at the innards of the wedge post, you will find that there is more "post" that IS NOT there, than there is "post" which is actually there. The "post" is mostly hollowed out, and additionally it has a couple of significant slots cut right through it.
So if you like nit-picking designs, one can make an argument that the post shown, if the slowness of changing can be fixed, is not bad compared to other "PRO" units.4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
post looks like?...
- 1 like
The one in the first picture though has the puller as a full dovetail shape and pulls both sides inwards. This pulls the holder away from the dovetails of the post leaving any clearance free to cause some play. This is not as good as the usual style piston tool posts because those at least force both sides of the dovetail solidly into contact. In short the one in the first post is not really any better than a flat surface with an anti rotation pin. Because of the way the puller acts on both sides of the holder's dovetail there's no firm locking force seen by the dovetail other than from the puller. If the puller were a one sided version like Randy's or the Hardinge unit that would make the one in the first post at least that good. But it fails to use the dovetail it has for the primary function of ensuring a firm and repeatable contact.
Chilliwack BC, Canada
............. This is not as good as the usual style piston tool posts because those at least force both sides of the dovetail solidly into contact. In short the one in the first post is not really any better than a flat surface with an anti rotation pin. Because of the way the puller acts on both sides of the holder's dovetail there's no firm locking force seen by the dovetail other than from the puller. If the puller were a one sided version like Randy's or the Hardinge unit that would make the one in the first post at least that good. But it fails to use the dovetail it has for the primary function of ensuring a firm and repeatable contact.
If you want to argue about the dovetail and alignment, which is a fair point, then there are others pretty bad also.... The type that you may even be referencing, where a taper piece is forced down by a screw and opens the split dovetail to wedge the part, for instance.
There, you have a split, and the way the dovetail opens up may or may not put it in the same place every time. Depends on many things, including how springy the post is, and which side is weaker than the other.
Slice up them hairs any way you like, the wedge comes out on top most all the time, and the competition may not be even close.4357 2773 5150 9120 9135 8645 1007 1190 2133 9120 5942
I'll grant you that in many a case we are talking hairs. But the one in the opening post compared to many seems to have a lot more split ends....
In my searching around for home shop made options before I broke down and bought an Aloris clone I was leaning heavily towards the one in the YT link below that borrows heavily on the MLA-23 DESIGN .
Shop Made Quick Change Toolpost - YouTube
Yes it's a split post style. But I'm thinking that it avoids the usual flexible feature you are describing by having the cone that forces the spreading of the dovetail also being the force that pulls the post down against the top of the slide.
And splitting hairs or not I'm confident that this is a better design in all respects.
What finally made me go with the Aloris clone was the separation between locking the post in position from the tool holder clamping. The gain being that I could remove and replace a holder and it would still hold the setting for the cut to within a thou or so.
--Doozer
https://www.homemadetools.net/forum/...ool-post-66191
Originally posted by BCRider View PostWhat finally made me go with the Aloris clone was the separation between locking the post in position from the tool holder clamping. The gain being that I could remove and replace a holder and it would still hold the setting for the cut to within a thou or so.
