About 8 years ago I had a request from a friend to make a half dozen boat prop shafts each about 6 ft. long out of 316 and although a little hesitant after a bad experience with some work hardening manganese steel I took the job on.
It cut very nicely, left a beautiful finish and was a treat to work with because I did not let the tool rub, only cut while in contact with the work. The previous bad experience with the manganese steel had left a bad taste in my mouth and got me out of that nasty habit of dwelling in the cut.
The taper on the shaft was cut with carbide tooling but the keyway, drilling, and single point threading were all done with HSS tools.
I'm not scared of it anymore.
