The big combs are made from SS TIG rods
The woods used for A, B and E are Marri, D is Olive and C is another Aussie native called Sheoak.
Big hook in "D" is also SS.
Cutting the comb teeth all to the same length was a bit of PITA so I ended up stuffing them into a couple of collets in collet blocks like this.
Set the collet "face end down" on a flat surface and tapped all the rods down as far as they would go - tightened the collet and held the other end up against a sanding disc to grind them all to the same length
