The kick start device in post #22 should be safe enough if the chain brake is engaged as recommended. I don't think hydro lock was a problem when first trying to crank it because IIRC there was no fuel in it when John tried it. He is stronger than I am but had a hard time. It was somewhat later that I took it to the Stihl dealer and he cranked it easily, but again, without fuel. We did add some fuel later and tried again, but I really didn't do much more with it. Since then I took the plug out again and cranked it a few times to verify it had spark, and it seemed easier to crank. It's supposed to warm up later this week so I'll be able to do some more on this chain saw.
My first chain saw was an old Homelite EZ with a blue metal case and a 20" bar. I bought it used around 1978. It had a compression release, and it started and ran well. But it was stolen along with other tools around 1990. I bought a Homelite XL and used it for quite a while until it stopped working.
I bought a Poulan Pro but never even tried it until maybe 5 years later. It worked pretty well for a couple years, and started reliably if I carefully followed the priming and adjustment procedure, but it got harder and harder. You might remember the thread I posted here a while ago. I had problems with the recoil spring. It might be worthwhile to get access to the crankshaft to use an electric drill to spin it up.
Eventually I gave up, and bought an Echo 56V battery powered saw, which has worked well, but isn't really powerful and rugged enough for some of the work. I also have a Remington 120 VAC electric saw, but the motor burned up while John was using it. Seems a lot of tools meet their death in his hands.
And I have another smaller 14" "Wen Hornet" electric that still works OK. But the manual oiler is crappy.
About a year ago I bought a "Coocheer" saw on eBay, and it worked fine for a while, but then began having problems. Last I worked on it it seemed to have no spark, so probably the magneto, but it also had a problem with a bad connection from the wire to the cap. Another thing to tackle when it is warmer.
Hopefully this Stihl will prove a better investment - so far it has cost me nothing but time.
