I may have jumped too quickly to get the cheap kits, but they should be good enough, and I'll keep the originals in case of problems. An OEM MAHLE cylinder and piston kit is about $200 and just the gaskets are about $25 for OEM. I've generally had pretty good luck with "cheap import stuff", so we'll see how this works out. I usually wind up with messed up gas powered equipment due to poor maintenance and neglect, but I hope to do better with this. That's one reason I like electric versions - simpler and low maintenance.
