Originally posted by J Tiers
View Post
If the table just moves the "applicator" and cannot turn it to orient with the movement, you are stuck with a pen type applicator, ball point, felt tip, or something like a newer tubular type drafting pen. Possibly a sprayer, if it can be controlled sufficiently.
It is starting to sound as if the best approach might be to paint the surface with a color contrasting with the body of the sheet. Then use a router or the like to cut through the paint to form the letters, in the same way as those door signs that are made of plastic having two contrasting color layers.
