Hey all,
with the new year I set out to add gear / pulley cutting to my little shop's abilities. This actually comes as an offshoot of a 3d printer build, thus the pulleys to be cut are GT2 timing pulleys, of various tooth counts. But for this discussion, lets just stick to a 16t pulley. With the recent completion of a dividing head, its time to focus on the tool grinding. I really have no experience grinding precise radii onto tools, I have a good idea of conceptually how the tool need to move to make the right shape, but I am paralysis with choices to get started. Will probably stick to HSS for these tools, but if the setup comes out nice, I may try to do one out of carbide.
here's what I have for the grinding procedure, please correct / answer / advise freely:
1) reduce diameter @ end
setup: spinning grind(plain bearing w/linear slide, fine adj in feed direction, set angle relative to wheel
2)grind flat
setup: same as above, with rotational lock. If grinding tangential, a vertical fine feed is needed. should this have some back rack? how much (cutting steel)?
3) noise & shoulder radii
setup: a pivot, positionable on 2 axis (3 if not using tool grinder table). Technically there is also a transition radius connecting these two—something to keep in mind, but might not require any action. Unclear order of ops here. The noise is the critical / position surface, but I may have to back & forth to the the clearance I need.
what grinder(s) to use?
6” general duty bench vise, would need to build a table solid base from scratch (prob not)
4” bench grinder, got this second hand, markings are german. its got a pretty nice spindle. Also has no table
6” tool grinder –grinds on wheel face & has tillable table with t slot parallel wheel
also have a dremel & angle grinders, but I doubt they will be of much use this one.
what wheel to use? Can I do this with a std grinding wheel, or do I need to work out a single lip setup?
Wheel dressing:
For a tool like this & absent a single lip grinding (~deckel) system, might it be better to build the same positioning system (whatever that is), but use a diamond in the collet to dress the wheel to the desired cutter profile?
tool holding:
For steps 1& 2 I’m thinking about using a collet chuck. I see machines like the Dekel that use U2 collets, which look a lot like 5c collets. I have other uses for an er-20 collet set, any reason I can’t use those instead?
If you can’t tell, my thoughts are ALL OVER THE PLACE, so I turn to you kind & intelligent folks to help me find the right path. Any answers, or just general advice would be greatly appreciated.
PS couple years back I picked up a cnc mill for dental implements. Its got a very nice & precise 2.5 axis positioning system. I don't have the software so I can run it cnc (yet), but I could make some cranks(i did just finish a dividing head) & mount a grinder to the base & use it as a manual machine. If people think this is a good route, I can give more details.
2)grind flat
Wheel dressing:
tool holding:
