I have no experience with the combination machine you have, so cannot comment directly
. Over the years we, at Toronto Society of Model Engineers have seen some very good models built on combination machines.
Those folk using them have commented that they need to plan carefully so that they do not waste time changing from one mode to another.
The results obtained, as with almost every machine, depend almost entirely on the patience, skill and determination of the user and not primarily with the quality of the machine.
When you reach the stage that you can do good work, while at the same time realising how much easier it would be to get the same results with less effort if you had better, larger or different tools then is perhaps the time to consider upgrading.
I have a second shop at our cottage,it is very small and I have bought a second hand combination machine( Maximat 7 )which will fit the space I have to use there. I hope I will enjoy it.
Regards David Powell,
