Or so many "experts" will tell you.
No I don't believe it and I just had a nice little demonstration of the phenomenon. And, was I milling some tough material, some sort of gummy or hard steel?
No, I was actually using the mill to rout some "melamine covered" particle board for a drawer front. I was routing slots for the sides and bottom to be glued into.
Had I just put the end mill in, and then forgotten to tighten it? Nope, it was untouched since a day or so ago when I was milling a slot in some steel. It had shown no tendency to come out then, and that involved a number of passes.
And, beside that, when I readjusted the cutter after spotting the issue, the nut was tight on the drawbar, and I had to beat the top of the bar with a copper hammer to pop the collet loose.
OK, by definition, if the cutter moved, it was not tight enough, because being tight enough is when the cutter does not move. That is, however, circular reasoning.
I don't know exactly why I bent down to look at it, I mean, who expects particle board, which cuts like butter, to pull out an end mill? Regardless, it was sure trying to cut right through and out the front side, which would really have annoyed me. It didn't get that deep, and there is enough of a correct depth cut all around to allow assembly to work OK. Major annoyance avoided.
The only Weldon end mill holder I have for this mill takes a larger cutter shank than what I was using. I have to use collets for most at the moment. That dang head on the Benchmaster is so large that I have to squat down to see much of the cutter in the work. I'll have to keep a better eye on it.
Anyhow, some pics, because no pics it did not happen. First is the "deep end", when I spotted the issue. Next are a couple showing the gradual "ramp" downward from the initial setting. You can also see the correct depth of the pass that cleared the slot to proper width.
