So there we have it. The outer rim has been drilled and everything put together for a "mock up". It looks good. Now that I know it will all fit together I have to take it apart, put the faceplate back on the lathe, and clamp the outer flywheel rim so that it is on center. Then take the faceplate off the lathe, reassemble it all, Loctite the spoke ends that fit into the hubs, let it set up 4 hours, then weld the spokes to the outer rim.
