Brian builds a Corliss
  • Today I drilled and tapped 18 holes in the cylinder. My cheeks are sore from clenched muscles!! The tapped holes under the brass thing are all put in with new spiral flute #4-40 taps and went very smoothly. The threads under the round flange are #5-40 and they were put in with an old "standard" tap, and there is a world of difference. I will talk to my tool guy and buy a couple of spiral flute #5-40 taps tomorrow.---Why are the bolts so long?--Because the shortest bolts I stock are 1/2" long. The bolts you see will all get shortened tomorrow.
    Design engineer
    Barrie, Ontario, Canada
    • Nice job Brian!
      Jon
      • So, here we are with 82 holes drilled and tapped. The only machining left on the cylinder is the very small holes that lead from the machined cavities thru to the ends of the cylinder. Never broke a tap---Amazing.
        Design engineer
        • Never broke a tap
          NEVER say that out loud!
          • WOW! Good job Brian.
            Jon
            • And today was a massive "try every bolt in every threaded hole day".--And they all fit---mostly. I had four clearance holes that had to be stretched a bit, but everything bolted up. Tomorrow was going to be a "shorten 100 bolts day" but before I do I will contact my nut and bolt supplier and see if I can buy shorter bolts.
              Design engineer
              • I call do-over on this. I know it's "just" a cover.
                Are those holes tool close to the edge?
                Is your block the 2.125" its supposed to be?
                • Block isn't full size--Lacks about 1/32" of being full size. No do-over. Bolt head will cover elongated slot and Mrs. belt sander will get rid of any overhanging brass.
                  Design engineer
                  • What are those covers covering? Your 3-D renderings show only the top and valve side.
                    USA Maryland 21030
                    • You do love that belt sander….
                      • That looks just fine to me. That is a lot of holes, a lot of tapping, a lot of dimensions.
                        That looks fine.
                        • Originally posted by sid pileski View Post
                          Not sure I would do-over either.
                          But it does look like "Mrs Belt Sander" will be cutting into screw-heads. That might change my mind.
                          • Belt sanders have their place.
                            This isn’t one of them
                            Yikes!
                            • Each of us has an opinion.
                              Brian's opinion is the one that counts.
                              • I guess……
                                Just trying to up the quality of the game….
                                Probably not going to happen here.
