Brian builds a Corliss
  • #76
    What makes you think that I'm human?
    Your fears. Electricity, and model steam boilers -- they make me a little nervous too.
    I think if I was to make a model steam engine, I'd start with the boiler. It would be low pressure, and unlikely to do any harm. The Corliss needs a boiler, not an air hose.
    Allan Ostling
    Phoenix, Arizona
    • #77
      The one negative about your personality Brian is that once you’ve made up your mind on something, no one can tell you anything. You’re stubborn as a mule.
      • #78
        ah, you know, general impression, bit of speculation
        • #79
          I have trained a lot of mules in my day. You are being insulting to mules when you compare Brian to a mule! Mules are smarter than horses and if you try to force a mule to do something you are going to have a problem. If you show a mule how to do something they will do it most times very willingly. Now Brian is a whole nuther ballgame! He is stubborn for sure and that can be a virtue or a hindrance. I like to think I am tenacious not stubborn. My wife disagrees! Carry on Brian. You will get this managed I am sure.
          • #80
            Well, fixing you lathe or not it was nice seeing a long shot of you shop. I find it interesting what each of our shops have in the way of layout and organization. Bob 😁
            • #81
              When you can match Brian's machining and designing skills you can think about criticizing his electrical skills. Just because it would not be your approach does not mean that it should not be Brian's approach. Carry on Brian.
              • #82
                That's a logical non-sequitur, but your point is for Brian to keep doing what he is comfortable with. I definitely agree, and can understand his attitude, even if I do encourage learning.
                • #83
                  An intelligent person recognizes their limitations and continues with what they are comfortable with. I also would dig deeper into the electrical problem, but I am not Brian.
                  • #84
                    Your all beating a dead mule!!!!
                    No Offense BF!!
                    • #85
                      Originally posted by GordonL View Post
                      When you can match Brian's machining skills you can think about criticizing his electrical skills
                      Well at least I got my laughs in for the day.
                      • #86
                        How did this become dump on Brian day? Keep it on subject.
                        • #87
                          It's in the truck. I'm ready to go to Toronto. No spills, no thrills, no mishaps. Hope we get a sunny day tomorrow.
                          Design engineer
                          Barrie, Ontario, Canada
                          • #88
                            Perhaps an expansion to a mobile army truck shop might be in your future Brian. Your lathe has racked up quite the road miles over the past few years.
                            I'm with the rest, in that I'd try to give it a go of fixing it myself. I have the belief that what one man can do, another can too, but can respect your decision to seek professional help from the dealer.
                            Best of luck with it!.
                            • #89
                              One thought is that if parts are needed, like the switch itself then it may well be faster just taking it there like Brian is doing. He is anxious to get making chips ASAP.
                              • #90
                                I'm not sure I've ever built anything with so many bolts in it!! The blue bolt heads are #4 which are 0.110" diameter and the redish ones are #5 which are 0.125" diameter. I'm currently looking for a source for #5 shoulder bolts for the linkage ends but haven't found them yet. I did manage to find some 3mm shoulder bolts and will use them if I have to.
                                Design engineer
