I'm starting to explore the High Frequency ham bands and made a loaded vertical antenna ( it was a good excuse to learn more about rotary / 4th axis machining as well ).
It came out pretty well, and now I get to learn about "noise floor" and all sorts of other fun stuff....
I turned down some 3/8 - 24 nuts to fit into the copper pipe lower element. The shoulders helped keep the nuts nicely aligned. I soldered it together after it was press fit;
The PVC coil form being cut. I cut a grooved "thread" from one end to the other ( the black is from the Sharpie I used to test the "cut" ).
I love that the G-code to do this is essentially this;
G1 X0.0 Y8.007 Z-0.01 A32400 F51.9965 (G1 Linear Move )
G1 X0.0 Y0.007 Z-0.01 A0.0 F51.9965 (G1 Linear Move )
Start position and rotation, end position and rotation, and time to get there.
If you are into this stuff I used the G93 Inverse Time Mode for the first time, which is necessary for mixed linear / rotary moves;
The finished coil. I made it cover a wide range of bands for testing / educational purposes, and expect to make more based on what I've learned so far.
And yes, having the red lead laying on the coil does affect it's behavior, gotta love the RF.
In action. I was surprised to learn how much the wind can affect a skinny little antenna;
