Leadscrew backlash reduction
Originally posted by Paul Alciatore View PostBacklash reducer? Sure is!
Wear increase? Also YES!
I think that Evan's Evanut was the best way I have seen.
And is that an acme screw or a ball screw?
Acme.
A new acetal nut would mean starting from scratch.
Originally posted by Bob Engelhardt View Post
If there still was some backlash,even at the tight ends, there wouldn't be any increased wear, would there?
Hence twice the wear. Splitting the nut is a bad idea,
Nothing wrong with backlash. If you think there is, seek help.
-DDZER
- Likes 1
Can't see it for a leadscrew, where's the problem that is being solved?
For a FEEDscrew, OK, it does eliminate an extra nuisance for certain operations, if the backlash is "effectively" zero afterward.
Problem is, the wear isn't even, so the nut cannot actually eliminate the issue. Only in some spots. The rest either still have backlash, or are too tight, depending.CNC machines only go through the motions
When you split the nut you cut the bearing surface area in half.
-D
I used to think "nothing wrong with backlash", e.g., in the context of cross feed screw, where you just always approach the cut in the same direction. But the other day I was fly cutting on my (loose) mill and I got some terrible dancing when the cut was climbing. It's very possible that my technique was lacking, but it seemed like less backlash would help.
Circular form tap.
Coil thread is what it is called.
Used in rebar nuts for concrete forms.
-DPeter - novice home machinist, modern motorcycle enthusiast.
Monarch 10EE 1942
