Another project, this one steam related, renovating old steam toy.
  • #61
    Originally posted by rickhann View Post
    Unexploded Ordinance???, Bomb???? No more dangerous than pumping up a bicycle tire. I would thing the volume of air under pressure would determine the extent of "danger due to a failure". Just my humble opinion. Rick
    Yes. A "bomb" may not be huge. But it can throw pieces around, and then also, it is destroyed. With water, if a leak occurs, in many cases the boiler can be repaired successfully, and it is just not a good idea to use air.
    You want to test with air pressure, I guess "you gotta do you". I'll stay with water, and away from your tests!
    4357 2773 5647 3671 3645 0087 1276
    "There's no pleasing these serpents"......Lewis Carroll
    • #62
      Sparky hit it on the head.. Fill the boiler with water, then use air pressure!!! to test, unless you are afraid of the air hose suddenly becoming weapon of mass destruction. A bit of critical thinking is in order. It's a toy! Rick
      • #63
        That's not as bad as straight air. Basically "air over hydraulic". With some flow limitation on the air, it's probably OK. But it just don't matter that it "is a toy". It is about a quart of volume, and if straight air was used, it could do some damage.
        Remember, I have no idea if ther are any defects in it, and I have had to repair it. It might be fine, or it might go pop.
        But I have the pump pretty much designed in CAD already. Now it gets the design finished and goes on the list. Seems like fun to make, and calculations say that at several times the pressure I need for this boiler, it will take less than 2 lb pressure on the lever to force in water.
        I also have to make a bunch of blanking plugs to replace various fittings that won't be on there. Not an issue, have two sizes already done, have several of the third type left to do.
        I may have to have the water gauge in place for the test, it is German, and has no boiler fittings for the gauge glass (see earlier photos). I may do a blanking plate instead, I don't want any chance of messing up the glass, I am no glass-blower.
        • #64
          As noted in post #58, just use a grease gun. The only fitting needed to apply pressure is a zerk. I've use one to hydro-test tanks and its dead simple. If you do a complete water fill, the amount of grease required to achieve pressure is minuscule and it will exit with the water drain. Or just go ahead and waste time making a one-time-use pump.
          Southwest Utah
          • #65
            It will NOT be one-time use, as-planned. I have intentions to do at least one or two more boilers, and intend to do some steam engines. I have materials for a couple fair sized all-copper firetube boilers. So, there is a reason to go ahead.
            But, you know what? If I never get to those, I won't feel that the design and construction of this pump is a waste. No doubt that will result in a "mind blown" response (per Doozer recently) but that's certainly not "my" problem.......
            Meanwhile, I have some blanking plugs to make, as well as a manifold for use in comparing pressure gauges, and checking safety valves of various sorts..
            • #66
              Hmph..... I got some of them done, but found that the last one was the size I had not obtained a die for. Got the tap, but the die was put of stock. It's an M5x0.5 thread, and I need to plug that hole, since that is the mounting for the gauge, and I do not want to have it in place for the test.
              Maybe I'll try single-pointing it, although I usually avoid doing that below about 40 tpi, as the slop in the halfnuts approaches the thread pitch. I may still hold out for the die, since the entire length of thread is only 5mm or so, and needs to be threaded close to the head.
              I made the rest of the ones I wanted. Here are some of them in the boiler (one would not be there due to needing a connection for feedwater to apply pressure). oddly, even though you could easily see the taper on the parting pip as it was being parted off, every single one of them broke off at the fat end, leaving most of the pip attached to the screw. I had purposely ground the tool to cut thinner at the part end, and fatter at the stock end, but it did not act as intended. Material was some hex stock I had that seems to be free machining.
              And those same ones loose. They will get a gasket or o-ring for the test:
              • #67
                I did design what should be a good pump. But I did not have a suitable piece of bronze or brass, and so I had a different idea.
                I don't need very high pressure for now, and I do have stupidly high water pressure. But the idea would work with most any workable water pressure.
                You may be familiar with the resistive voltage divider.... it occurred to me that I can do a simple resistive water pressure reducer, since ideally I do not need any real water flow at pressure. All I really need is the "voltage" (pressure).
                So, supplying the water through a small orifice (resistive), and having an adjustable "leak", should allow me to adjust for nearly any pressure in the range that I want. Pressure with the "leak" closed is obviously full pipe pressure, and with the "leak" much larger than the orifice is equally obviously essentially zero pressure.
                So, with a needle type valve, I ought to be able to get any pressure I want between the two by suitable adjustment. Might be a bit fiddly to set, but that's not much of an issue. I can set it up, then open a valve between the pressure output and the boiler or other item under test.
                Besides the boiler, I have some gauges that could use calibration, so I can get one with a suitable range calibrated, then use it as a standard for checking the others. * I just need to make a suitable manifold, which I would need to use anyhow, and screw in an inlet orifice and a pressure setting valve. Also needed is a standard gauge, and an output to whatever is being tested.
                * In practice, I would likely use the principle that if two unrelated measuring instruments give the same reading for a given "input", they are probably correct. If a third one agrees, the probability goes much higher.
                • #68
                  Using that method for the boiler should be pretty safe. If there is a leak, or rupture, the small orifice or tubing will greatly limit to flow, and you'd get nothing more than a trickle. You should be able to verify operation of the gauge and also test whatever safety valve(s) are on it.
                  USA Maryland 21030
