I saw this video pop up. Someone the actual procedures are a little crude (indexing, live tooling) but it is an interesting concept using the live center in the chuck so you can power the carriage. Basically turns it into a make shift planer/shaper.
Interesting use of a lathe
I do like the way he used the power feed and adding a hand held drill to power the final cutter.
But I always have to question the accuracy of gears made with such crude indexing methods. He did use a large diameter disk so that the errors would be less on the gear, but still .........Paul A.
That's old school small shop indexing, very old school.The shortest distance between two points is a circle of infinite diameter.
Southwestern Ontario. Canada
Just plain ole' turning until 6:00, then step-and-repeat until 10:45 when the drill comes in. Then step-and-repeat until the end. 15:10 - man, those are shetty gear teeth!Last edited by Bob Engelhardt; 03-29-2022, 07:04 PM.
Originally posted by The Metal Butcher View PostMan needs a TOS where you can run the feed in neutral.
You probably could hook up a VFD to the feed motor though.
Originally posted by oxford View Post
The one I used if I remember correctly was only in rapid. It might be ok if you were using it like a planner, but would probably be too fast for live tooling.
Certain ones can run the feeds like normal with the spindle in neutral. Gotta be one of the top lever ones, I think with the dual lever?
I didn’t really post the video for the “gear” making content, like I said in the OP some (all) of the video was a little crude for the prodecdures. It was more so of powering the carriage without the workpiece moving. Depending on what you have for machines at your disposal it would really open up some options for long parts that wouldn’t go in the mill.
This would be good for cutting long keyways in shafts, either with live tooling or shaper/planer style. We just had a thread about cutting a long keyway in a lead screw, you could get it done this way if it was your only option. Follow rest behind long/skinny parts would most likely be needed.
Stanko ant it seems TOS can run in neutral, with a stanko you have to contrive a spindle lock as it floats about but other than that the carriage powers with the spindle static, I suppose it’s going to wear the hell out of the leadscrew nuts, using it as a planer but with a milling cutter and a powered spindle it might be an ok solution ( I’ve only tinkered with a thread milling attachment on a lathe once, it worked but I certainly hit the depth by luck I think)
mark
