Originally posted by oxford
View Post
Interesting use of a lathe
Interesting way of using a lathe that I haven't seen before. A little crude on the indexing though, and no way to lock it in positively. If I was doing that, the shaft would have rotated slightly on me and screwed it all up. As for the shape of the resulting 'teeth'- yes, a grind on the drill bit would have changed that. But you are also looking at a very small material removal rate, especially at the tip of the drill bit. It's ingenious, and a way to get the job done if there is no other way, or proper tool to cut the gullets.I seldom do anything within the scope of logical reason and calculated cost/benefit, etc- I'm following my passion-
👍 1
Originally posted by boslab View PostStanko ant it seems TOS can run in neutral, with a stanko you have to contrive a spindle lock as it floats about but other than that the carriage powers with the spindle static, I suppose it’s going to wear the hell out of the leadscrew nuts, using it as a planer but with a milling cutter and a powered spindle it might be an ok solution ( I’ve only tinkered with a thread milling attachment on a lathe once, it worked but I certainly hit the depth by luck I think)
markLocation: The Black Forest in Germany
The concept of slotting something using that trick is very interesting. And not only for gears... although I'll have to watch it to see what the fuss is about. I'm thinking that things like keyways or slotting rounded grip features would make this a pretty slick trick.Chilliwack BC, Canada
👍 1
There are a lot of posts here complaining about the tooth form... He wasn't making a gear, he was making a splined shaft. I suspect the use of the word "gear" in the title is a result of English being a second language.
He posts another video about making an "internal gear" that mates with the splined shaft he just made here: https://www.youtube.com/watch?v=BczEh2hFFrY
I think it's brilliant. I've done this many times to make keyways and splines but never made the leap to using a live center. I cranked that bastard by hand...
