Hi Group,
I have a Miller Syncrowave 250 machine that I have used for TIG welding steel but never aluminum. I need some basic guidance on setup for doing some welding of aluminum.
I have a water cooled torch, foot pedal control, green tip tungsten, and have Argon gas. The settings are where I need the help. If I can give any other specifics I will try...The settings in the pictures are just there when the picture was taken nothing specific.
The basics that I know are, Set for AC, use the remote for amperage control, Set the amps for the project, and that's it. If you know of any videos that tal about the specifics of this welder I'm all for it, I just couldn't find any that specific.
The Questions are,
I'll take any and all suggestions, other than to get a newer welder. This is what I have and I need to learn how to use it, I hope someone can help me with the basics, then I can learn as I go through trial and error. I've got scraps of 6061 and rod that is 5000 series I think, I'd have to go check to make sure.
I look forward to any help that can be provided.
TX
Mr fixit for the family
Chris
The Questions are,
- The output contactor switch, panel or remote?
- Creator time control ON or OFF & how much?
- AC balance control what setting?
- High Frequency start continuous OFF or start?
- ARC Force dig ON or OFF and what setting?
TX
Chris
